您需要 登录 才可以下载或查看,没有帐号?注册
价格:84元素币 销售总额:756元素币 购买人数:9
这个插件包括了你在Substance Painter视口中直接使用RGBA遮罩所需的一切。这是一种常见的做法,用于制作后面需要用于着色器的遮罩,由于它是直接在3D视口中,所以不需要像使用其他软件(如Photoshop)时需要猜测。 其中包括Substance Painter模板文件,用于工作的智能材质,RGB和RGBA选项的导出模板,以及关于如何设置/使用所有内容的教程视频。 This package includes everything you need to start working directly with RGBA masks in the viewport of Substance Painter. This is a common practice used for making masks that will later be needed for shaders, and since it's directly in a 3D viewport there is no guesswork needed like when using other software such as photoshop.
Included is a Substance Painter template files, smart material to work in, export templates for RGB and RGBA options, and an instructional video on how to set up/use everything.
